Left mirror
I've had this problem before.
The most likely things are:
- software: the control computer has got confused about what its supposed to be doing
- hardware: there is a problem with the mirror electronics or wiring and the ECU either doesn't know what position the mirror is in to move it, or the position/move signal isn't reaching the mirror.
Can you move the mirror around using the joystick adjuster? If so then the motor bit is still working so its more likely to be the computer is confused, if you can hard reset it then that might fix it (you'll need to make it relearn the position you want it to be in when reversing).
domino_z
03-19-2018 01:04 PM
jwmciti
04-19-2013 03:12 PM
stephen11962
08-03-2010 08:38 PM
