License Plate Lights
I have this same issue on my 09 XF premium luxury, I've had to use double sided tape or just shoving them in in a way that makes them sort of stuck in position. It happened after I replaced the lights with leds, must a certain way of removing them that I did not do correctly.
Received 3,209 Likes
I fitted T10 SMD LED globes to both my XFs and never had a problem with either, solid as a rock.
Maybe that is because they are a bit longer longer than the stock globes and they jam in pretty tight in the globe holder?
With the added bonus of bright white light light instead of the dull sickly yellow of the stock globes.
DannyRobertHoward
11-17-2015 11:38 AM
Avro RJ
11-16-2015 08:19 AM
