Lights not working properly
Hello, I have a 08 XF and my head lights are acting weird or I'm just using them wrong. Okay, so when I set the lights to "auto" I dont have any exterior lights on. Only setting I can get my headlamps on is the headlamps setting. But when I turn the car off with that setting selected, the headlamps go off but sidelamps turn on. Which is annoying because I cant leave my car with sidelamps turned on. And finally when I select exit delays lamps, I again dont have any lamps turn on. Any help?
They're not acting weird. When you shut off the ignition with headlights on and switch in the "on" position you are trying to leave your headlights on with the ignition off. To protect from a dead battery the car shuts off the headlights but leaves on the parking lights front and rear. To turn these off you need to move the switch to "off." As an alternative, you can select one of the auto settings. In any of these settings, everything remains off until it gets fairly dark and then the headlights come on, shown by a green light symbol in the instrument panel. There are several auto settings giving various headlight on delays after shutdown. Reading the manual is always helpful.
Is my only option to have headlamps ON and always turn them to OFF when I leave the car?
Received 3,274 Likes
It sounds like you need to install a set of after-market DRLs.
Not too expensive or all that difficult.
It is even possible to retrofit factory DRLs to an 08 XF, in the chrome "blades", but they are like rocking horse doo doo to find. Keep checking eBay and you might get lucky.
Or else you can fit after-market LED DRLs in the blades, plenty on eBay, I fitted a set to my old 2010 XFS.
The only hassle is that some don't fit all that brilliantly and you have to cut huge slices out of the black backing plastic.
Either way you need to wire them up properly so they turn off when the main lights turn on, which you may need some help to do. I did as I am hopeless at electrical wiring!
You don't give your location but it sounds like Canada with a used model originally sold in the US. Other than manually switching the lights on and off, there is another option. Your dealer can change the settings so that you have what models originally sold in Canada have, which are daytime running lights (front headlights on a reduced power setting) on all the time unless full headlights are needed. Another headlight setting they can change is for whether the car is used in a drive-on-the-right or a drive-on-the-left country (yes, the light pattern is different).
This is a completely unrelated problem that was very common with the early (2008-9) XF's. There is a simple dealer fix for this (Note I said simple and not cheap. No Jaguar dealer service work is anything close to cheap.).
This is a completely unrelated problem that was very common with the early (2008-9) XF's. There is a simple dealer fix for this (Note I said simple and not cheap. No Jaguar dealer service work is anything close to cheap.).[/QUOTE]
I took the panel off and cleared it off dust and flies and now seems to be working as normal.
Received 6,366 Likes
BoHoTom
10-10-2012 06:02 AM
TxJag2004
11-16-2010 08:12 PM
rajinder75
10-14-2008 10:42 AM
