Long term implications of no under-engine/gearbox skid plate/shroud?
2009 XF Luxury (U.S. Spec)- recently took the car to a quick change oil service establishment where they lost some of the screws that secure the under-engine fairing to the car, resulting in the front portion of said piece to flutter and then drag for several miles at highway speeds. The whole shroud itself is intact but scratched up, and the larger openings which have what I assume would be larger bolts and washers in them are damaged. I took off the whole assembly in order to drive normally...my question is what risk am I exposing my car to by having the undercarriage exposed like this and how long can I reasonably go without repairing or replacing this skid plate?
The under-tray helps with aerodynamics and helps keep things cleaner and to a small extent, free from road debris causing damage.
You do not need it to drive, but I would not drive for long like that.
And I agree, discuss this issue with the oil change place, they should stand behind their work.
Received 3,226 Likes
mhopkins (05-14-2024)
![Icon Bowrofl](https://www.jaguarforums.com/forum/images/smilies/icon_bowrofl.gif)
Oz...I just read your write up on painting the lettering on the fenders .AWESOME!!!!
....but really..we are talking about the XF under-tray not your bikini F-type undertray. Recall from your XF days that it comes in two pieces and stretches all the way back to the middle of the car
One added benefit I found to having the undertray off...I change the oil the old fashioned way now. ALL of it comes out from the drain plug. Don't even use the oil evacuator pump anymore cause the oil evacuator always left some oil in the sump. Now I get all of the old fluid out and I fell better being able to pan it and check for dreaded sparkling metal shavings..lol..don't know how much more the little 3.0L can go under the loads I am exposing her to. ...hahaha
I agree!
This past winter, I couldn't avoid what I thought was a lump of snow, in the middle of the road (cars on both sides, so I couldn't swerve, and somebody right on my tail, so I couldn't brake sharply). Turned out it was more ice than snow, and I hit it with a loud whack. Put a couple of cracks in it. A new one is pretty pricey, I think, so I'm going to look for a good used one....
