Looking for a rear diff
Well,
Ive been looking for a rear diff for my car now for about 2 weeks........no luck anywhere can anyone give me a hand maybe lead me in the right direction??
If not Ill be looking to sell the car AS IS outside the diff no issues. Id take 16,500 for it Canadian......
OK so looking through your previous posts, I see now why you are asking about a replacement diff...
https://www.jaguarforums.com/forum/x...e-help-142146/
R32689 means your car came from the factory with the Ford / Visteon 8" diff.
You can buy replacement seals, and bearings for this unit. It can be re-built.
Same diff as the 2003-2007 S-Type, X350 XJ, the 2006/2007 X150 XK
Lots of info on seals, bearings, and other items needed in this thread:
https://www.jaguarforums.com/forum/x...arings-102296/
Seals can be purchased from Jaguar as spare parts, no need to buy a complete diff.
Well thats great news! I was starting to feel like maybe this service manager was taking me for a ride the more i dug for info from him.
What is the typical failure on these diffs that are leaking usually just bearings and seals?
When I took the car in to this dealer he told me the axle was worn hmmmm
Check with a Ford dealer as they have access to those parts and know how to fit them. My 09 just had this repair done and for a lot less by a local friendly Ford dealer.
However, if your diff is howling or whining then you are put of luck as replacement gear sets for Jaguar diffs are apparently nla.
I know my way around ford vehicles pretty well had many mustangs and have built rear ends for them more then once.
Im more worried about pulling this thing out to find out i cant get parts for it then im really stuck. I dont have any whinning or grinding ive been keeping it toped up and its not to bad of a leak.
Seems like a hell of a job to drop this rear end out to open it up im going to crawl under her and have a look for some ID tags on the diff tonight and take a better look at how i may pull this thing out......Im sure being a Jaguar they have more then one "special" tool needed
Yes a Ford dealer can probably help, the diff is the same as the last of the Lincoln LS...
If it's only the axle seal leaking then you wouldn't have to drop the whole diff out of the car, just remove that driveshaft and replace the seal.
Special tools? Yes there are a couple listed;
Halfshaft splitter 307-443 + 307-442 (prize the driveshaft out of the diff, because it's held in with a circlip)
Seal installation tool 205-532 (properly locate the new seal in place, as you hammer it in)
Seal protection tool 205-461 (protects the seal as you push the driveshaft back in)
Ford dealer should have these tools.
In saying that, the guy who rebuilt my diff did not, and it wasn't a problem for him.
If you download the JTIS here on the forum, the diff sections from the 2004 S-Type would apply to your XF as well (same diff).
jagular (06-04-2015)
Do I have to disconnect the axle from the wheel side as well of is there enough play in it to just pull out of the diff and let it hang while i change the seal? It was pulled out by the Jag dealer as i said and they told me the axle was worn and the whole diff needed to be replaced……..
jagular (06-05-2015)
