Looks about right with 15mm spacers all around.
Old 03-07-2015 | 11:01 AM
Bigg Will's Avatar
Default Looks about right with 15mm spacers all around.
Installed the H&R 15mm wheel spacers, and really like the look of "Higgins" now. I've not detected any real difference in ride or handling, but short of buying new wheels this is the quickest and cheapest way of making a car look more aggressive.
Old 03-07-2015 | 11:33 AM
Gpalace's Avatar
Agree 100% ...a much better stance with a subtle 15mm mod. A big difference in appearance I think.
Bigg Will (03-10-2015)
Old 03-07-2015 | 11:34 AM
2010 Kyanite XFR's Avatar
I told you it makes a difference! Subtle but needed for sure.
Bigg Will (03-07-2015)
Old 03-07-2015 | 03:26 PM
chXFS's Avatar
I have 15mm front and 25mm rear. The rear looks good, almost flush. I'm not liking the front as much, the wheels sit to far in so I purchased 20mm for the front. Haven't installed yet.
Old 03-07-2015 | 03:56 PM
Mr Sharky's Avatar
Where do you buy the spacers from/ Do they have the concentric wheel centers?
Old 03-07-2015 | 04:32 PM
Bigg Will's Avatar
H&R's are hub centric and XF specific. Just Google for an order location.
Old 03-07-2015 | 04:36 PM
damienedwards's Avatar
Hi all.....
I've always worried about wheel spacers screwing up the handling.......so any real diffetence also as an engineer i also worry about the extra load being placed on the hub and bearing......last structural worry......how much thread do you stcking out of the end of the hub adapter nuts???
I should prob stop worrying and buy some!!!
Any side pics showing how much the wheel is sticking out??
Cheers folks
Old 03-08-2015 | 01:01 AM
panels's Avatar
Post some images you guys.... Sounds like those who have done it like it!
Old 03-08-2015 | 06:45 PM
chXFS's Avatar
My opinion is that 15mm is a waist of time. The wheels are still very much sunk into the wheel wells. Maybe if your not lowered its not as noticeable. But I'm lowered with H&R springs, and I have 15mm front and 25mm rear in the pics below. As you can see, I can easily go another 5mm front and rear.
So I ordered 20mm and I'm gonna replace the front. I might even go to 30mm in the rear. If you look at most the forum members on here who have aftermarket wheels, you will notice that the average is a 15-17mm in the front and 25-32mm in the rear over stock.
Attached Thumbnails Looks about right with 15mm spacers all around.-image-2321342886.jpg   Looks about right with 15mm spacers all around.-image-1705473329.jpg   Looks about right with 15mm spacers all around.-image-2966872451.jpg   Looks about right with 15mm spacers all around.-image-219594694.jpg   Looks about right with 15mm spacers all around.-image-989766473.jpg
Looks about right with 15mm spacers all around.-image-1413248868.jpg   Looks about right with 15mm spacers all around.-image-2421762665.jpg
Guru_97 (10-02-2021)
Old 03-08-2015 | 10:33 PM
Bigg Will's Avatar
Just not trying to do the ricer look with 25/20mm. And So.CALi roads are just not very forgiving when it come to exact fitment flush wheels.
Old 03-08-2015 | 10:45 PM
Bigg Will's Avatar
Originally Posted by damienedwards
Hi all.....
Cheers folks
Well the H&R spacers bolt to the hub and then the wheel bolts to the spacer, so your basically bolting to a full stud.
And as far as added stress, I would just go conservative on the spacer thickness. Any mods you do add some stress, but I've heard no ill up to 15mm F/R. Good luck!
Old 03-08-2015 | 11:48 PM
chXFS's Avatar
RICER?? You do realize that if you had aftermarket wheels 9inch in the front with 35 offset and 10inch with 42 offset, that would equate to the front wheel being pushed out 20mm and the rear would be pushed out 30mm more than stock. So I guess every forum member here that has aftermarket wheels you are calling a RICER. Ohh, and my car doesn't look ricer at all nor does any forum members here that have aftermarket wheels.
Old 03-09-2015 | 01:09 AM
sparkenzap's Avatar
"Ohh, and my car doesn't look ricer at all nor does any forum members here that have aftermarket wheels."
And that, sir, would be your opinion. As we all know, opinions are like...
Old 03-09-2015 | 02:47 AM
plums's Avatar
You would want to do some reading on "scrub radius" and "roll center".
Of course, you already know about tolerance stackup.
Old 03-09-2015 | 06:56 AM
Bigg Will's Avatar
Yes and your key word here is AFTERMARKET wheels which have OTHER design elements to compensate for the +/- offset used. But on the FACTORY XF R S wheel MY OPINION (Just as your opinion is +15mm is a "waste of time"?) is anything over +15mm offset pushes the wheels out too far (Ricer), and is far to unforgiving to use on So Cali roads.
Old 03-09-2015 | 07:06 AM
Cambo's Avatar
Yes we've all got opinions and we are all entitled to them.
Keep it civil please gents.
Bigg Will (03-09-2015)
Old 03-09-2015 | 07:49 AM
panels's Avatar
How about 20mm or 25mm spacers on the rear with 305 tires? Would THAT be too much?
(Think I'm headed towards 15mm and 305's...)
Old 03-09-2015 | 02:47 PM
fabfive's Avatar
Hey chXFS,
Can you possibly do a rear end shot of the car? I was thinking 25mm for the rear as I have the same wheels, but not lowered.
I know there's a difference of opinion on hub-centric spacers, but do any members think it would void the extended warranty on my vehicle?
Might be silly to ask but I'd like to hear a honest answer on what part(s) they think might fail due to the spacers on this car.
Thanks for the pics, and hope there's some info to sway my decision to purchase or not purchase a set.
Old 03-09-2015 | 03:48 PM
Main concern on wear is the hub bearing which is put under an increased rotational load......and maybe the suspension upper and lower bushings.....some one did however rightly point out about factory tolerances but no way will it be near 15-20mm....on the hub face to pivoting components its going to be more like 5mm......working your way through the suspension it will stack up more.....on the front its going to put additional stress on the steering rack and tie rods/bushes as hitting bumps will put additional loads into them.......i'd not go more than 15mm.
The following 2 users liked this post by damienedwards:
Bigg Will (03-10-2015), fabfive (03-10-2015)
Old 03-09-2015 | 05:02 PM
hlgeorge's Avatar
Not to mention the more you push the wheel out of the wheel wells, the more trash ends up on the outside of the car.
The following 2 users liked this post by hlgeorge:
Quick Reply: Looks about right with 15mm spacers all around.
