Loss of indicator sound
I have a 2012 Jaguar XF Premium Luxury. The indicator sounds have stopped working - the indicators still work but there is no sound. Jaguar Servicing has quoted $2000 to replace a part where the speaker is located and $1000 to fit the part. To add insult to injury, the extended warranty expired 2 months before the problem started. Does anyone have any suggestions for a less expensive solution?
Received 3,239 Likes
Apparently the speaker electronics are part of the instrument cluster, which is fairly easy to remove, see here: Plea for help - instrument cluster speaker and the thread linked in post #4.
But after that I can't help!
Shislop (09-12-2017)
If you can get the instrument cluster out, this part should fit the cluster, it replaces the original speaker which is marked on a spare that I have as "DIGISOUND FB-BMS-3408-01". Looks like it will need to be resoldered but is an easy job - if you can't do it you should be easily able to find someone who can for a lot less than the dealership want.
smgdata (12-05-2017)
