Love my 22'' wheels.
Not sure what the offsets are on mine, because Savini custom shaves and drills when you order. High in the front (I would assume +35-+40), low in the rear (+15-+20, again I would assume.) Call Savini they may be able to tell you what the range is. Here's their number... 866-779-4646
My bad, my tire size is 245/30/22 front and 295/25/22 rear.
Here is my XF on 2s.
RodTee XF (03-03-2015)
You can hear a bit of rub against the fender well plastics on "steering lock" (mainly when wheels are turned completely to the left). As for any rubbing in the back only when there's quite a bit of weight in the back seat and you hit a good dip. My usual rear passenger load consist of 2 teens and a pre-teen and I rarely have rubbing issues. Only time I tend to get rub in the rear is when I have larger adults in the back and I hit a dip in the road.
QUOTE=Mean Gene;1172392]Do you experience any rubbing issues, and if so when? i.e. Sharp turns and/or passengers in in car...[/QUOTE]
this is exactly what i have.......
Rodtee where did you get the jaguar center caps that fit?
yes, he is right on point ^^^^ no male friends allowed in the backseats of my car.... petite women only or in his case kids.
The_Ikon (01-24-2022)
