Maximum power from the 5.0 supercharged?
I was just starting to wonder if anyone had any idea as to the max horsepower that the 5.0 can take on stock internals.
Kyanite.. I think he broke his rear on launch at the track, what was the failure?
Just cooking up some ideas, like lysholm supercharger, there are adapaters for eaton m110's
600bhp max for drive train reliability.........675hp really is the engine limit on stock internals and my UK tuner is getting close @667hp.....exhaust/cats/intake.....upper and lower pulleys-re map with larger intercooler......I'm running about 580hp at the ctank however the diff may have jumped ship......its at tje transmissipn shop currently for diagnosis!!
it might be time for maybe a ford 9inch.
I am a bit disappointed that an engine that makes 560 in the xfr-s only has about another 100 hp in it.
Lots of other factors come into play when making HP, the cast crank in our AJ 133SC is the biggest limitation, the block is probably good for 750hp but we'd run out of fuel with the stock injectors at as said 600hp. The stock diff is only good for about 490hp (Before you all jump on my head, Unless you run slicks and a non legal tune you'll never see that much power from as standing start, our electronics guarantee that). Then theirs the drive shaft, anything over 570 you need to at the least hoop it over 600 you need to look at a loosing the flex joints (x2) for U joints, And a solid instead of splined front half.
These guys, https://www.drive2.ru/r/jaguar/1354304/ are making stupid hp, but have been through 2 engines. Making hp is easy but not cheap, Making RELIABLE hp is even more $$$, As the saying goes "Speed cost money, so how fast do you want to go?"
Panthro (12-13-2023)
Stock diff is only good for 490 hp, out of an engine that runs on average 510hp? okay, 10-12% transmission loss, but man is that way too close the edge.
I had thought the direct injectors could supply a hell of a lot of fuel, their duty range is supposed to be very wide.
I could always try to get my hands on a stock crank and have something better made, there are a lot of companies that do that.
Do we have real U joints or more of guibo setup like BMW ?
(for the uninformed, a guibo is sort of two flexible rubber plates bolted together to make a mating surface)
We have a flex joint from the trans to the driveshaft, the it's splined through to a carrier to a u joint and then flexed again to the center section diff.
Try "better' Crank rods and pistons sir, all I'm guessing first run too. And you can't throw that much additional fuel and air at an engine without addressing the cams, And You still haven't touched the trans or torque converter..lol again Speed cost Money, how fast do you want to go?
Direct Injectors do have a wide operating cycle just not wide enough to cover an additional 200 hp and still have good drivabilty. Most of you high hp engines (Chryslers Hell Cat 707hp, and GM's Super charged LT 658hp) use a dual strategies fuel map, that's some big $$$ development.
just no, you dont need to bother, you have a decent intercooler already.
Water and meth injection have been done for so long I cant even remember. I was doing it 20 years ago on boosted engines. I think it is funny that bmw is still trying to figure out a way to make it work for winters when its been done to death for years (we just use a blend of water and methanol, easily found as windshield wiper fluid).
BMW is only going to water injection on high boosted small engines because it is cheaper to do than a proper intercooler.
Sure I can go on and on and debate the pros and cons, the heat absorption during phase change (it sucks a ton of heat up going from liquid to gas) the higher octane analaog to the water and meth, the steam cleaning of the internals.. but man.. it is such a finicky pain in the ***.
I know the two piece driveshaft is weak too, I want to get a one piece and put poly bushings in the diff to keep wheel hop to a minimum. The LSD and maybe a tranny and diff cooler to keep things kosher at the road course. But I have learned the drivetrain on these Jags are a little brittle when you race hard. I don't know what to do if the actual subframe and pumpkin are weak.
My XFR is out of warranty and I want to build it pretty stout now, I need to figure out this drivetrain problem before I take on an endeavor this big.
I had thought that the xf supercharged/xfr/xfr-s all already have an LSD.
What part of the diff is weak? The Pumpkin? The final drive or bearings? or the Internals themselves? I want to put a LSD in mine, but if the whole thing is weak there is no point. If I had a one piece propshaft, LSD and billet final drive and axles would that work?
I have read when it is tracked, it has a habit of opening up and breaking when driven hard on a stock car. Put some sticky tires on it and up the power we have a problem.
I would rather put in a torsen or clutch type LSD and forget the electronics, at least those wont overheat and grenade when you put some stress on them, and their handling is consistent.
I am not a 100% on that. the 2010 supercharged and up are identical to the xfr and xfr-s aside from some code, front facia, hood, some seats.
