Melted Cylinder 8 Spark Plug....2nd time
Hi Gents,
Trying to figure this one out... My 2012 XFR melted the cylinder 8 stock spark plug (center electrode destroyed) for the 2nd time in a year. Before it went "pop" the cylinder was throughing a misfire code. I added some BG44K and then it went into "reduced performance." Anyone else have this issue? Thinking perhaps a clogged injector, carbon buildup? Only mods upper pulley, y-pipe intake, tune for pulley.
Received 2,626 Likes
Well,... I drove around and some nice cold Cali air last night and punched it a couple times...on the third time....limp mode again! Just like before, cylinder 8 misfire and probably melted the plug. Well going to change injector this time.
I would agree on a clogged injector or injector at end of life.
If you are using an independent shop you can get the injector a lot cheaper off of ebay. Your shop would also need to buy the injector installation tool.
I would actually do what the forum members advised and have the injector swapper to a different cylinder and see if the problem follows, if it does you know it is the injector, if not and the issue stays on number 8, then it might be a fuel delivery issue, or electrical supply to the injector.
So I had my Indy replace the spark plug. It was collapsed again. Unfortunately they didn't have the injector puller and I didn't want them to perform the change without one. The car runs fine with the new plug. I think two things might have an impact on the plugs melting - 1.) It always happens after I hit the rev limiter once or twice in succession after driving hard. 2.) BG44k cleaner is in the gas when they melt.
Could this combination increase the cylinder heat so much that it melts #8?
Received 2,190 Likes
Eurotoys (11-23-2018)
Lagonia
02-12-2022 11:18 PM
