memory seat stopped working
[QUOTE=jagular;664740]If neither the seat nor the steering wheel and mirror adjustments work I suspect the switch or door connection in the harness. If some functions work but not others then the affected component or perhaps a central software glitch. A dealer is likely the only recourse for diagnosis
Hi thanks for the info , that does make sense as the problem is intermittent , going to put it on a diagnostic at the weekend ... Will let you know....
