Meridian sound upgrade for base 2012 xf need help with programming
As the title says I have a 2012 xf with the base sound system 10 speakers my amp has low 8 on sticker..I found a 2013 xf that has a 11 speaker Meridian system has a subwoofer under the spare tire I'm getting all speakers and amp from the car I think
I only need to change the ccf in the front audio head unit to have the subwoofer adjustment level.Can someone tell me how to go about doing this? I have JLR SSD with Mongoose cable,or if someone has this exact system they can send me a screenshot of there
ACM files used ,thank's ..
Yes with some help from a couple of members on here I figured it out..This thread helped me the most read all the way through it,you need to get engineering mode to change/edit CCF to make the sub-woofer adjustment show on audio screen !
https://www.jaguarforums.com/forum/x...-wrong-221956/
ilwill77
Audio/Visual Electronics
12-26-2012 12:47 PM
