message center annoyance
What is the difference in temperature between the temperature when you check the pressure and the temperature where you are driving?
If the temperature is 55F in your garage but 32F outside then your tpms is going to display low pressure because the pressure is low. Tire pressure changes 1 psi for every 10 degrees F so 55F in your garage when you check the pressure is going to be 2 psi higher than at 32 F outside.
X308XJR
05-20-2019 06:50 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
