Mina Exhaust or Muffler Delete
I am contemplating on getting a Mina Exhaust for my XF, but after reading several threads, looks like it has drone issues around 2k RPM. I am thinking to maybe just replace the rear mufflers with straight pipes instead and save me the $900.
Anyone on here used a muffler shop to cut off the rear mufflers and put straight pipes in place or any thoughts on doing this? Will it be obnoxiously loud?
I've been planning on doing what's in this thread:
https://www.jaguarforums.com/forum/x...dified-108504/
Basically, gutting the silencers and putting in an x-pipe. Maybe when my car stops having issues and I'm able to find a muffler shop that will do it.
The following 2 users liked this post by Bigg Will:
BostonKiller (11-17-2015),
Jaaaggg (11-16-2015)
If you are planning on selling your Mina, I'll buy it if the price is right. I really do like the Mina and I much prefer using a quality product over doing a hack job on a car like this. But spending $900 and not liking the sound will be a waste of that money.
I have quicksilver mufflers on mine and i think its fine. I'm actually swapping out the center rearmost resonator this weekend as i've welded in straight pipes.........
my friend has an XKR that has swapped out the rear mufflers for paramount straight pipes and removed the rearmost resonator and its MUCH louder than mine.
If you put in an X pipe with the rear mufflers ot will be about the same volume as the standard center section with both front silencer and resonator removed.......i done this on my previous XKR ......the reason is that as the exhaust pulses cross over they can flow through both silencets from each bank and not just one if u had no cross pipe........tbh though i hated it. Lost that muscle car growl and thrap that i love.........just my opinion though. Plenty of people do it and love it.
Last edited by n8ertot; 11-17-2015 at 05:28 PM. Reason: Because I know very little about exhaust
Well it depends on what kind of sound you are after and if you are tuning for power.......an X or H pipe will give u more power than straights. But u loose the muscle car burble a little......straights are louder.....then H then and X pipe is the quitest. I'm doing straights this weekend......as i want the standard center section to flow more to my quicksilver back boxes and be a bit louder......may well be too loud.....if it is i'll delete the forward silencer and run the middle section straight through to the quicksilver boxes......i'm also getting it dynoed again with the center resonator out to see what it does to the power curve.....
I used a fuse tap - the trunk fuse box is easily accessible. Really easy, safe and clean install.. Tapped into the pedestrian safety system 10a fuse, no problem at all with it..
Any additional performance would be great, but I mostly just want to be able to actually hear the damned thing. I don't get why somebody would think a person buying a supercharged v8 would want to have the engine nearly silent. I'll let you be the guinea pig and wait to hear how a straight pipe works out.
The one I found was with the Mina exhaust, which sounded brilliant, but I don't intend to go that route. I don't really want it too loud. Just enough to rumble at low speed and scream when throttled, but be quiet when I'm cruising and need to take a call.
WRXtranceformed (12-07-2015)
