That's not as loud as I thought it would be. Maybe a touch more than I'm looking for, but it means I could probably do some fairly high flow mufflers and be fine (if I don't just remove the valves from the stock ones).
If you remove the resonators in the centre section and add an X-pipe it gets much louder - for the better..
The Varex unit is straight pipe when the valve is open and channels the gases (and noise) through the chambers when the valve is closed. Hence Open = Loud and Closed = Quiet.
Closed is quieter than stock.
Open is as loud as a straight pipe.
Perfect blend in my opinion.
I wonder how adding 200 Cell Sports cats would sound with a fully open exhaust...
Great vid Thor, sound is very mellow and sounds less poppy than mine.......link is with Quicksilver boxes and second resonator delete.......goung to squeeze in a power run hopefull monday to see how much power the center resonator is stealing.....
I have mine at the shop right now getting the resonators replaced with an X pipe (as well as figuring out whether they can fix a leaking metal pipe going to the radiator. Trans fluid, we think). I'm pretty excited to hear how it turns out.
Great vid Thor, sound is very mellow and sounds less poppy than mine.......link is with Quicksilver boxes and second resonator delete.......goung to squeeze in a power run hopefull monday to see how much power the center resonator is stealing.....XFR startup and revs - YouTube
Car sounds amazing, it's pretty smooth too at idle.
I am doing the same tomorrow morning. My mid section has a muffler, two resonators, and a H-pipe. Getting all of that replaced with an X-Pipe and straight pipes, I am excited to see the outcome.
Well, there's a halt to my plans. Turns out the trans line leaking is going to run me over $1k to fix and I'm going to need to also replace the water pump. Tough to justify this upgrade on top of those costs right now, so I guess I'll have to go without until later. Fortunately I've already seen a good DIY on replacing and upgrading the pump, so that should help a bit. I don't have a lift to do the trans replacement, so it's off to the dealer.
Trans line that cost a grand to replace? I'd get a second opinion.
Well mine doesn't drone. got it off Ebay for $500.
Fit like a glove too!
Very nice deal Will..
do you happen to know if this will fit the '12 XF NA version? I only read about XFR's having Mina put on, never a NA 5.0...since my exhaust ports are oval instead of dual oulets..worried about the clearances.
So had the car back on the dyno with the center resonator delete........v interesting!!!
Lost 8whp at 5800 rpm.......but gained a huge amount of torque!! From about 2000 through to 4000 rpm anout 30ft/lb......through to 5000 rpm where it equalises with the first session..........butt dyno confirms the lump of extra torque!!!
Can you recap what you have to achieve those numbers? All performance mods please?
I am heading to a customizer exhaust place Saturday and want to know do I can match it.
sorry buddy a bit late!! My XFR has quicksilver rear boxes, the center section has the standard forward single box muffler and the second center resonator has been removed and replaced with straight pipes.......on the intake side the air silencers have been removed so the intake is smooth.....has K&N airfilters with most of the lower half of the airboxes cut away.........we do not believe the car is re-mapped and it definately has the standard pulley. All my dyno runs are using 98RON fuel.........we do know its putting out more whp/torque to the rollers with this set up that the F type R they had on the dyno!!!! Quick vid of the car on the dyno with the above set up.........don't forget to post a vid of ypure exhaust!!!
I had a new center section made today for my 2013 5.0 SC. (475hp) Went with straight pipes for now. May decide to have X-pipe installed later. This was built so that I can swap in the stock section later if desired.
Stock front pipes outlet to center section. Notice the reduced pipe ends and a raised bead. Kind of a pain to work with, but we managed.
Stock center out of car
New center looking rear to front
Better view of the connection and braces
No more resonators, may do X-pipe at a later time in this section
Front connection. Slip-fit and small tack weld to keep from moving. Can easily grind down and slide off if I want to revert back to stock.
New pipes front to rear
Plenty of clearances
Center connection to rear section. I should be able to install aftermarket (Mina) at a later time if I choose to do so.
I have a video of the sound, just have to upload and tag. Quite a bit more rumble, a hint of raspy cackle with a blip of the loud pedal. No drone at any speed, very faint popping/cackle under decel when manually down shifting aggressively.
Does sound really good. I thing the straight through rear silencers give the exhaust a deeper note......my next step is to try a H pipe......and another dyno run
A week ago I fitted an H-pipe in place of the central muffler. The central resonators are still in place as are the stock rear mufflers, unmodified.
Only the slightest increase in loudness and no drone at all.
A few weeks ago I fitted a TCP intake and surprisingly it beefed up the exhaust note quite a bit, sounded really good.
After fitting the H-pipe the exhaust note has changed, as others have reported. It's lost some of the beefiness that the TCP intake caused, and it's now smoother and more refined. I actually prefer the pre H-pipe note! On the plus side the supercharger whine is now a little more pronounced, partly due to the TCP intake and partly due to the H-pipe.
Next step (after trying the XKR-S tune yet again tomorrow!) is to refit the straight-through rear mufflers I took off a few months ago because they were just too loud and droney, and see if they are now better behaved with the H-pipe in place.
I doubt they will be any better, but it's worth a try.
It's interesting how the sound changes, both from intake and exhaust, in tone and volume with different modifications. The stranger part is they often don't end up how you thought they would go ie. more flow yet higher tone, and the intake making the exhaust louder and a bit deeper.
Glad I've found a sound I'm happy with. Good luck with your tune again.
