Missing Nav Module
Hi,
First of all, i would like to thank you for taking the time to read this post.
I have a 2009 Jaguar XF. (USA). I purchased the car but it is missing the rear Navigation module! I cant seem to find a second hand Navigation Module anywhere online and they run about $2,000 at the dealer!
Does this car use any module compatible with other cars? Land Rover?? I can find Navigation modules for very car but the 2009 Jaguar XF USA Version...
ANY help is greatly appreciated.
Thank You !
Thank You !
![Icon Captain](https://www.jaguarforums.com/forum/images/smilies/icon_captain.gif)
EDIT: I seem to recall it is a standard unit, I'll check and get back here.
Three system variants are used depending on market. The basic computer architecture is Ford develoed and used. I would visit the forecourt of a large Ford dealer and have a look at the satnav displays used. I would be very surprised if you didn't find a similar system. Btw is the gps antenna in place? I would assume the wiring loom is there though. The good thing is that the nav doesn't require IDS configuration. Is navigation a choice in the main menu?
Thanks for the detailed response. The GPS antenna is in place. The wiring loom is also there and the navigation is a choice on the main menu.
Thanks again for your time!
Samheath100
09-20-2015 08:21 AM
