My passenger window has stuck half way up
At least it is half way up not half way down. Did the motor simply stop, did it sound different? Did you try the switch on that side or just the master one on the drivers side? I'm assuming the others are working? I would still check for a possible fuse issue before getting too involved. You can always try a battery disconnect to see if the computers are just confused. Only time I ever had a window stop working was slowly over time.
Joe Gandalf
08-13-2017 04:07 PM
