HI everyone, DO you mind if you Help me?
I jut replaced My water pump and after testing out the car I noticed another coolant leak popped up But its bubbling and barely drip leaking from the seems of the metal Spacer on this Part, attached to the Oil pan 2 bolts or 5 bolts hold it on with a metal spacer ?
However I cant find anything about this part or what is it .. I will post photos..
Please give advice, and part numbers and possible repair options thanks
Jaguar XF 2015 3.0 s/c UK model Red
if zoomed in you can see the coolant leak from the Seems between the spacer any advice ?
thanks
Jayson
Reason: added photo
Looks like the vacuum pump for the brake servo. It looks like oil leaking not coolant. you could try tightening the 2 bolts ,or replace the gasket.
Thank you so much !! I had no idea the name of this part or how to repair I did tighten the 2 bolts but when the motor is hot and running.. i see a tiny bit of bubbling and the occasional drip coming from it.
I googled the part. i just need a new seal ... my only question is when i start to take it apart, will break fluid and Oil/ Or coolant both start pouring out?
should be easy to change a seal ? knock on wood ?
let me know what you think ?
Jayson
Jaguar XF 3.0 v6 S/C Uk Model red
I have not had to do this job myself but you can search this forum and the X351 Forum with the Search Term " vacuum pump oil leak" and see experience of people who have done the job. General advice is to remove some oil from the the engine before removing the pump so none leaks out on the floor.
Thanks. I was able to find a easy .version 2 rebuild kit with the o rings and rubber rings. 34 dollars on RKX I will be doing the job this weekend thanks for helping me.
