NAV System Issue
I had a similar issue with the Volvo I had before my Jag XF.
The Volvo dealer ended up replacing the Nav "antenna" inside the shark fin, NO FIX, replaced the antenna cable between the antenna & the unit, NO FIX, replaced the player/unit that holds the disc, NO FIX, replaced the computer control unit in the rear fender (for the NAV unit) FIXED.
FYI, Mine would follow my route, if I turned right it turned right, if I went 5 miles north, it went 5 miles north and so on, It was just not my true location....at one point when I was at the dealer, I had me about 40-50miles away, in the middle of a lake, BUT it showed me driving though the lake perfectly as if it was on the actual roads around the dealership.
Question, Did you recently have the battery replaced.....that's when all my issues in the Volvo appeared. It seems that the slight spike in electrical system from a dead (disconnected) battery to a NEW battery fried the computer control unit.
Good luck.
Good luck.
I'd suggest finding your friendly dealer and let them investigate.
Good luck!
99xk8guy
06-05-2023 06:28 AM
