Navigation appears to be missing states
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Here is an oddity: I went to create a stored memory point in my 2009 XF today and tried to change the "search area" (i.e. state) to Iowa.
However, it does not appear that "IA" is an option, and then I noticed other states are "missing" as well.
Is there a second disk I should be looking for? Is this a system setting of some kind I should turn on.
Help?!
Thanks.
Help?!
Thanks.
Received 2,191 Likes
Don't know the year of the disc that you have, but the 2009 MY Nav needs to have the 2010-2011 discs installed. They correct a software problem that caused the Nav system to malfunction when traveling on restricted lane roads. You can order the disc set through Jaguar NA, Navteq, or a dealer for $199
How does a 2-disc system work?
Thanks.
