Need Coolant asap will this work ?
My Coolant service is due, Jaguar dealership in my area is out of the coolant and on back order 130$ per gallon. Ridiculous!!!
I'm going to drain and refill the system with a friend .. will these coolants Work ? please look at link and let me know if these will work !
thanks Jag Fans
Jayson D. USA, California
My car RED 2015 Jag XF 3.0 S/C non US model AWD
https://www.carparts.com/details/Jag...E&gclsrc=aw.ds
https://www.rmeuropean.com/Products/...SABEgKlkfD_BwE
https://www.ebay.com/itm/39346934294...6tA8c5xg8RXpe0
thanks Jag Fans
Well...the FSM for the V8 XF calls out WSS-M97B44-D spec coolant. This is a Ford specification for coolant...and it's dexcool. I just used this: Prestone 1 Gallon Orange Concentrate Antifreeze/Coolant AF888 | O'Reil (oreillyauto.com)
I would like to UPDATE everyone that reads this ... I went to another Jaguar Dealership and spoke to the master tech working in the bays . He told me... BUY the Range Rover Coolant as it is the same but 35% cheaper. so showed me both Jaguar and range rover coolant gallons. Jaguar coast 130$ a gallon where Range Over / land rover coolant has the same stickers and chemical make up but much cheaper.
anyway I found my coolant at the dealership range over side WSS m97b44- D * D variant because they do not support or make m97b44. anymore. Ford also sells the same coolant I checked the Label on the fords Coolant. Problem solved SO if your jaguar takes the Orange or Pinkish /Orange is what the tech said, Buy range rover. Same Parts, Engine cooling system. Do not fear identical.
Have a great Day Jag community
2 bottles is enough for a Flush and fill. Mix 50/50 needed.
Jayson D.
USA , California
lucasschwartz
03-30-2022 09:25 AM
