Need help! 2009 XF Coolant pump missing power wire. Was disconnected when I bought it
Just bought this 2009 Jaguar XF supercharged and threw a po2601 code and I look under and the pumps not even connected. I searched for 2 hours and can’t find what to connect too. What is it supposed to be wired to? A relay? I searched all around the pump and nothing
The harness for that plug should be located in the foam strip that seals between the side of the radiator and the panel; the bottom end of the foam strip is visible in the bottom left of your photo. From memory, the connector from the vehicle harness protrudes forward through that foam strip, the harness from the pump goes pretty much directly toward the rear of the car from the top of the pump. It would be hidden behind the pump in your photo. Let me know if you can't locate it there and if I get a chance with the bottom tray off I'll see where it goes from there so you can find the harness. Are you getting a 'restricted performance' message? Your intercoolers are just dead weight without that pump running.
GGG (04-06-2021)
I've moved your question from General Tech Help to X250 forum. This is the place to post technical questions about your model.
It may help to visit Gus at JagRepair.com - Jaguar Repair Information Resource.
He has kindly posted the electrical info that you need.
Don't forget to send a Paypal donation to help defray cost of the website.
They ain't free.
They ain't free.
