Need help: coolant light on, coolant level is fine
Had to pull over because the "Warning: Coolant level low" light was flashing, but the level was above the minimum line when I stopped. I had to grab an uber to a meeting so I don't know how the level is now that the engine is cooler.
Two points: I've already replaced two water pumps within the last year.
The "trunk open" warning was also flashing on at the same time, but the trunk was shut.
I'd prefer to drive instead of towing it and having it in for the weekend, but there's no temperature gauge to determine if the engine is too hot (which is dumb).
Any ideas? Thermostat? Level indicator?
THANK YOU.
THANK YOU.
Had to pull over because the "Warning: Coolant level low" light was flashing, but the level was above the minimum line when I stopped. I had to grab an uber to a meeting so I don't know how the level is now that the engine is cooler. Two points: I've already replaced two water pumps within the last year. The "trunk open" warning was also flashing on at the same time, but the trunk was shut. I'd prefer to drive instead of towing it and having it in for the weekend, but there's no temperature gauge to determine if the engine is too hot (which is dumb). Any ideas? Thermostat? Level indicator? THANK YOU.
Blackcoog (06-15-2015)
The float is bigger than the fill hole. i.e. the float was put in and the two halves were glued together. I can't figure out how it could come out.... It is also very difficult to work on the float, it's like a particularly tortuous form of keyhole surgery. I have the same issue and the float is currently wired in the 'up' position. I plan to buy a new tank, but was quoted $212 for the tank, by the dealer. The SC is slightly different to the NA and I haven't found a cheaper option for the SC on ebay yet.
I pulled the float out of my tank yesterday. For the moment I removed the sensor from the tank and taped the float to the sensor to eliminate the light. I'll have to either find another float or something I can stick on the shaft under the float that will lift the float up with the coolant level.
See the picture attached. The black plastic piece is the top that snaps onto the top of the shaft and keeps the float from floating away. The orange doughnut is the float.
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
