New battery/alternator "battery not charging"
Received 2,192 Likes
well you figured it out. I was going to say you need to check that wire, it has a fusible link in it. It always gets blown when people jump start a car with battery cables and get careless . if the cable clamps bite into that wire when hooking up to the battery you just provided a short to ground and there goes the fuse. seen many independent shops replace alternators because they don't know the car and the owners are out a lot of money needlessly for a $5 replaceable link. then they come to us cause its still not charging and we replace the link.
hi, could you tell me where this wire is as I am having the same problem now? Thankyou.
Willchill
01-18-2011 08:39 PM
