New XF Owner with a question about accessories
First and foremost, love my 2011. Picked it up last week and it is everything I hoped for.
I do find that the trunk is very slippery and a trip to the grocery store had bags sliding all over the place.
My previous car had a cargo net which Jaguar does not seem to offer. I do plan to buy a Trunk Utility Mat, which should help give a little grip, but wondered if any of you have tried the Collapsible Cargo Carrier.
My dealer does not stock them, will order it for me, but I would be required to buy it. I want to know how big it is, how it locks down etc, but can't find any info.
Any help would be appreciated.
Oh, and another thing. There is no Sunglass holder/compartment. Where the hell do you all put your sunglasses!
I have the collapsible cargo carrier. It is very good, but pricey like all factory accessories. It has sturdy handles for lifting in and out of the trunk. When not in use it folds flat. It has nifty Velcro secured dividers with basically infinite options to divide the space. It has a grippy rubber bottom surface that stays put when the carrier is loaded with anything slight heavy. When empty it slides around the trunk floor as there are no tie downs and nowhere to tie any on.
On balance it is an excellent design and stays put when in use with anything that might need to not slide around. Light stuff like a coat or pair if shoes will not be heavy enough but, so what? Sliding around doesn't hurt anything though the rubber bottom is grippy enough that the trunk carpet shows the effects of the sliding
Another options include an aftermarket folding nylon carrier with hook Velcro patches to grip the carpet. These will zip closed and ave packets but no dividers. I have a couple of these in other cars and by work fine at a third the cost.
I prefer my Jaguar carrier for style and function. The rubber trunk liner is a tad ugly but very practical if you carry scruffy stuff frequently. My dealer ordered one for me by mistake and I thought it looked very Volvo when they tried it for fit. I sent it back.
theesir (11-28-2011)
We use a Highland Space Master Soft Sided Organizer. It is large enough to carry the sort of loose stuff you tend to have in your trunk e.g. flashlights, map books, seat protectors (for our dogs), emergency compressor etc. The bottom has velcro strips that stop it sliding about (they can be covered) and it is equipped with partitions and handles. It has proved very handy and works well. It does not seem to slide around and it protects the contents very well. We purchased it from the ubiquitous supplier of everything, Amazon.
OP - You mentioned you had a cargo net in your previous car. If you don't care about compartments, try the floor cargo net for the XJ. Hooks to the floor hooks and is far cheaper that the collapsible unit.
https://www.jaguarparts.com/catalog/...oducts_id=1161
Need4Spd (11-26-2011)
A simple fix that's worked for me is a thick black bath towel (or 2), folded or hemmed to fit. Have done this in my last 3 Jaguars, stuff doesn't slide on them, suitcases roll on them (as long as they're folded neatly), once spread flat they stay in place, if you put in something with a sharp edge it doesn't cut the felt liner, you can clean the trunk by pulling them out and shaking them...
thanks for the suggestions. The towel idea is definetely a good one. In my old car I had a cargo net that was vertical and attached side to side about 2 feet from the trunk opening itself. This allowed me to put groceries there, even a propane tank if I needed to go fill it without it rolling around the trunk. The ideas of a "flat" net are good, and it would work in my propane tank example, but the groceries don't need to be strapped down.
The cargo carrier may be the solution I am looking for. I wish I knew what the plastic clips shown here in a picture (https://www.jaguarparts.com/catalog/...rgoCarrier.jpg) are intended to be clipped TO!
Those clips match the other half of each clip on the other side of the carrier, they clip together when the unit is folded flat to keep it that way. It would be feasible to make up a set of straps to clip into these and connect to the tie down rings in each corner of the trunk, but that is not part of the design.
Cargo Net - 2011 Jaguar XF
I have been looking around this forum and the internet for a cargo or trunk net for my 2011 XF. I was wondering if anyone could confirm if the cargo net/trunk net will fit my XF. Although there is some discussion around this topic, there doesnt appear to be a definitive answer. The former post referred this link
Many thanks.
Many thanks.
FS[Western US]: Jaguar xk accessories for sale
jfitzoz
09-07-2015 04:28 AM
