No battery or emergency key. How do i get in trunk?
I took my car to sorry Walmart Auto for a battery swap. My emergency key fell out the fob a while ago which has been inconvenient. The guy takes the battery out the car and slams the trunk shut. With no key and no power how do i get into the trunk. Tried under the hood and the terminal inside the car but no luck. My car is stuck there windows down and idk what to do. Any help???
AOTEAROA634 (10-22-2022)
HTH !
thistle4celtic1 (10-18-2022)
You may have experienced the truck cable failure at the same time as the process shown in the video should have worked as I have used that method.
A locksmith can use a lock pick ( if he has the right one) in your door to ascertain the key code to cut a key to open your truck, I have done this after finding a locksmith that can do it. You cannot get into the truck from inside the car as you cannot remove the back seat unless you have access to your trunk.
I have been through this and until i found a locksmith that could otherwise you have to cut a large hole to access and damage your latch to open it.
I have purchased my own lock picks for my x300, x308 and XF but have not used them as it's a skill you need to practice.
The following video shows how to get the back seats out, https://www.youtube.com/watch?v=3Nwdo9qXeno
If the positive cable is dangling somewhere in to boot, it may be best not to try and feed power in elsewhere.
I’ll try and explain why this works.
Just say you remove your battery and place it on the ground. Now get some jumper cables- connect positive at battery to positive battery cable in car. Negative to negative in car. Everything in car has power, right?
Now disconnect jumper cable from negative battery cable in car and instead connect to an earth point in car. You still have power to car interior lights work etc etc…the car metal is one big negative terminal
But, hey isn’t the negative battery cable disconnected ? Yes, but you are effectively connected to it through the car metal. ( now obviously you wouldn’t do the following in real life
If you were to now clamp the positive jumper cable say 6 inches from the positive cable clamp that normally attaches to the battery in the car ( stripping the insulation first for electrical contact) it would still power the car. Do this every 6 inches until you reach the fuse box…yes, it still powers the car even though the battery cables are disconnected in the boot… HTH
Xeno
16
09-03-2021 08:38 PM
Magicland
24
08-03-2017 10:33 AM
