No DAB signal
Old 09-19-2017, 03:56 AM
philb24's Avatar
Default No DAB signal
We have a2012 XF-S 275 portfolio & since we purchased the vehicle have had DAB signal after checking & joining Topix
we found the following , my question is has anybody had theres done & how much was it ?
Thanks in advance Phil
JTB00338
TECHNICAL BULLETIN
21 JAN 2014
© Jaguar Land Rover Limited
All rights reserved.
Information
SECTION:
415-00
Subject/Concern:
DAB + Upgrade Kit For Gen 2.1
AFFECTED VEHICLE RANGE:
Model:
Model Year:
VIN:
XJ Range (X351)
2010-2012
V00001-V39427
XF (X250)
2012
S20753-S61362
MARKETS:
All Except NAS
CONDITION SUMMARY:
Situation:
A customer may report a total loss of reception when using Digital radio.
Cause:
Due to a broadcasting technology change some markets are switching to DAB+ (Digital Audio Broadcast+), as a result the customer may request that an upgrade kit be installed to their vehicle.
NOTE:
THIS UPGRADE IS AT THE CUSTOMER'S EXPENSE AND IS NOT TO BE CLAIMED UNDER WARRANTY.
Action:
Install a Digital Audio Broadcasting (DAB+) upgrade kit.
PARTS:
Part Number
Description
Quantity:
C2D33982
DAB+ upgrade kit
SERVICE INSTRUCTION:
CAUTION:
This procedure requires SDD DVD136.02 and Calibration File 157 loaded or later.
Connect the Jaguar approved battery support unit / power supply.
Connect SDD to the vehicle and begin a new diagnostic session, by reading the VIN for the current vehicle and initiating the data collect sequence.
Make sure that the Touch Screen software is at the latest level.
Click here to run : Configure existing module - Front control/display interface module (high level display front) (50750 / 136.00)
Where no internet connection is available:
Select Diagnosis session type.
Select any of the following symptoms:
Electrical - Information and entertainment system – Touch screen display.
Select the 'extras' tab'.
Run : Configure existing module - Front control/display interface module (high level display front).
Install DAB+ upgrade kit (see Topix Workshop Manual, Section 415 - 01A, Satellite Radio Tuner).
Follow the SDD prompts.
Where no internet access is available.
Select Service Functions session type.
Run : Add / remove accessories : Digital radio control module upgrade.
When all tasks are complete, exit the current session by selecting the Session tab and then selecting the Close Session option.
Disconnect SDD and the battery support unit /power supply.
xdave
06-28-2022 01:40 PM
Cambo
04-18-2022 02:15 PM
Cambo
72
02-17-2022 07:17 AM
fourbyfourbyfar
10-31-2009 03:02 PM
Quick Reply: No DAB signal
