Noisy vacuum pump?
Hello, I too have a 2011 XF 5.0SC and I’ve had a whining sound for maybe 2 weeks that is most heard at idle that at first thought was my HPFP but I replaced both and it’s continued. The noise is typically heard once I’ve warmed up and come to stops at lights but goes quieter when I shift to Neutral. Have you tried that? If so did it have the same effect? I’ve not been able to find any information what I’ve been noticing. Also having some questions regarding the Fuel Pump Duty Cycle % for ON status which I originally thought could be the cause for the sounds as I was under the impression it was the HPFP sounding like they were being starved of fuel. Are you any familiar with that? Have you checked live data at all when you heard this sound?
Are you able to post a video so I can compare to the noise in hearing? Also, I use the icarsoft LR v3.0 which shows all modules available and for my vehicle there’s about 250 points of live data viewable in just the ECU alone. Definitely recommend purchasing at least something that will show some live fed data. This model was about $300 shipped to California.
No video, but I can get one. Pump STILL hasn’t fixed my issue. Only thing left it could be is the pump cam timing out. So sick of this POS design. From what I’m reading that adjustment is like an 18 hour job and I was told there’s a bolt for the cam chain tensioner that requires engine to be lifted/pulled to get it out. FML 🤦♂️
What bolt needs the Engine out to be removed? Only one I’m aware of that could be is the Crank bolt and I’ve already been in and out of that one with engine and radiator still in. It is most certainly a HUGE Pain in the *** and could be a lot easier if removed but it’s definitely accessible at least in my vehicle. The shaft that the HPFP and Vacuum pumps are driven by the crank gear which will need lots of stuff to be removed in order to get to.
Tork Monster
02-05-2019 03:37 PM
