Not again....
A few months ago, my Xf was getting the "fuel level low" warning when it should not have. Took it to the dealer and three days later car was returned after replacing the fuel line. Last week I had the warning pop up, but it went away. Today, I'm getting it pretty often. Not sure what is going on with this XF
Feeling frustrated right now.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Sounds like the fuel tank sender is bad. I find it hard to see how a fuel line could affect the signal from the tank to the instruments. Does your fuel consumption display seem correct? This must use the fuel level sender signal and the ECU fuel flow signal to calculate fuel consumption. Something is triggering the low fuel message and surely that has to be the fuel level sender.
There must be a fault in the fuel level sender circuit. My guess is there is a faulty fuel level sender. These sometimes fail intermittently. For the fuel consumption to recover from blank as opposed to beginning again the ECU must be getting and remembering a signal. If the signal is interrupted it shows blank because it cannot update the calculation. It uses and creates a running average. The low fuel warning will be triggered by a separate signal from the tank sender.
Gille
06-05-2014 11:17 PM
