OBD2 PIDs for tire pressure?
Okay, so I just got this:
Super Mini Small ELM327 V1.5 OBD2 OBDII Bluetooth Adapter Scanner TORQUE ANDROID | eBay
And this:
Torque — OBD2 Performance and Diagnostics for your Vehicle
And now I want to display individual tire pressure, if possible. Does anybody know the PIDs for this data?
Regarding the adapter, it's so small it barely protrudes out of the dash. It's a bit fidly to get it to connect. The car BT was fighting with it, until I told it not to connect to the phone. Also, when I re-connect it takes a bit of time. But generally seems to work. The Torque app is awesome, to. If only for the 0-60 times, it's worth the $5 plus $25 for adapter.
And this:
I been using this for many years. Same setup as yours just my adaptor is the longer , older version. The only complaint is the initial connection as it sometimes takes forever or wont connect. Make sure you go through those settings menus good as there is a few settings that can make it respond faster as default seems to be a bit laggy.
This peak rated horsepower number is only achieved at peak hp rpm. Without a dyno brake measuring actual whp, and an accurate algorithm to reverse engineer the crank power needed to yield that whpnumber, I don't see how the accelerometer type device could ever calculate this number accurately since you only see it at full throttle, full boost and the specified rpm which will be around 5,000 rpm or so for a supercharged engine.
I am thinking about purchasing a diagnostic tool for my XF. For the last 10 years I have been using Ross-Tech VAG-COM (Ross-Tech: VCDS) on my Audis. Its a pretty useful tool that allows you to data log; scan codes and clear codes; and code some modules using the cable/software program and your laptop.
Is the system described above the equivalent for Jaguar's? Is there a better more powerful tool? Do people prefer the bluetooth/phone over corded laptop? Do each have the same capabilities? Finally, can I code the TPMS using any of these tools? Thanks in advance and sorry for all of the questions.
I've been looking for Jag PIDS that can be used for monitoring since I got the same setup, but haven't made any progress. I did find this site, but it seems to be all error codes, uncategorized in any way:
Error Code Manufacturer Listing
I bought this bluetooth OBDII adapter the other day. Works great for me. After you pair it for the first time it connects every time on it's own. I have the free torque app now but I might spring for the $5 version.
Bump
Sorry to resurect, but I've been looking for an answer to this question, too. The VAG-COM lets you reprogram almost all your codes and factory settings, while these OBD-II scanners and apps mostly seem to just monitor things and reset error codes. Can't seem to find a VAG-COM equivalent for the Jag. Any new info out there?
Bump
Muddydog (11-03-2013)
scooternva
20
09-27-2023 11:25 AM
