Odd finding after changing front pads on 10 SC
Mounted Delphi pads this morning. They mounted up just fine BUT....they move the outboard side of the caliper out just far enough to bring the driver side front rim into contact with the caliper! The clearance has always been quite small with the Jag rims on my snows. No problem with the stock RIMs but the jag rims on my snows just won't clear with the thick new pads on one side! Its odd because the passenger side still has enough clearance. Strange!
No, they are floating calipers so the distance between the outer face of the rotor and the inner face of the caliper is totally dictated by the thickness of the outer pad. The thicker the pad the further out the caliper sits. The rims were fairly close before the change and the new pads were enough to cause a clearance issue. I'm glad I tried a wheel spin before putting the car back on the ground and driving because the contact was firm!. Would have made a mess.
So, anyone running the Auriga Jag rims for snows on an SC beware. A 5mm spacer fixes things just fine. 3mm would probably be enough.
Thx for letting me know. I have a 2011 xf s/c and I'm just about to purchase a set of Auriga rims for winter use. At least I know I need spacers now. Where did u get the 5mm spacers from and how much were they? I assume these spacers are only needed on the fronts since the rear calipers are much smaller? Or do u need on all 4 wheels to make sure everything is balanced?
I would say that even the fronts with anything but brand new pads will also be fine without spacers.
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
