Oil Change
Matthew Gouin (02-25-2016)
Here we go again. Mobil 1 does NOT "meet" that spec. The oil manufacturer claims it is "suitable for use" in that application. Jaguar says you should use oil that meets the spec.
So, someone with a reasonable understanding of the English language and what the words "meets specifications" means can decide for themselves whether they want to use Mobil 1.
Although it is hard (for me) to believe, there are folks here that try to argue that those words mean the same thing. And then others quote federal warranty laws on whether you must use one brand or another, which really has no bearing on whether a brand meets the spec or not.
If you have a CPO warranty, why not call the dealer you expect to use for warranty claims and ask them? Unless you plan to hire an attorney to fight Jaguar in case of a problem, then the dealer's opinion (and Jaguar's) is really the only opinion that matters! If you do not, I agree it is probably fine to use oil "suitable for use".
The following 2 users liked this post by DPK:
Jaaaggg (02-26-2016),
So If it were me..I'd change out the Mobil 1 sooner than the recommended Jaguar scheduled time of 12,000 miles or one year...say 5000 to 6000 miles and get back on Castrol OE Professional, or the Red Line I mentioned earlier.
I mean really...this is a car..it's not like you are investing your f'ing family fortune into whether or not the warranty will cover you if you used the wrong oil..do you think they will actually check what oil you used!!!!...lol....sorry, I'm sure someone will rebutal, but ****ing hell man...do you think the car will conk out because of a different spec. Of oil,...if so then the car is not worth buying or keeping. Do you have the funds to pump $1,100 into the engine upkeep every year or not? If you want to keep the engine as you would a high end car, then that is what it will take. If you just want to drive the godam beast into the ground, then put whatever oil you want into the crank and go about your business. Then get another one. It's not going to matter either way.
Etip (02-26-2016)
Well, they go to the trouble of putting a ultraviolet dye in the oil for the sole purpose of identification, and the CPO documentation that came with my XFR delivered by Hennessy Jaguar had a separate piece of paper that I signed a copy of, which dealt with one topic- the requirement to use oil with the WSS M2C925-A 5W20 specification. So, ahem, YES, I do believe they MIGHT check what oil is in it if there was an engine failure.
And btw...I am not trying to hurt anyone's feelings here and I apologize to those that I offended by my comment. Just having fun with you guys.
No offense taken! In general, I agree with your general position. As far as "telling them to shove it", when you do any negotiation, you need to decide what is important and what is not. Since I felt like my CPO warranty was coming at the right price (nearly free), after days of negotiation on the car price, I determined that it made no difference to me if I used the "right" oil or not. If I find the paper, I will post a scan of it. BTW, my guess is that you have never read a new car contract before signing IT!
Have a look at this link for the dye. Look at the last paragraph. Of course, it is characterized by a way for the customer to know the right oil has been put in at an oil change. Yeah, right, I'll just poke my UV light down in the fill hole with a mirror and look at the wash on the wall!
Castrol EDGE Professional
I think you'll be fine...the Jag spec which really is a Ford Spec..(WSS M2C925-A 5W-20) is for extended run time oil, and now that Jag sets the limits at 12,000 miles or one year, they wanted an oil to hold up for that length of time..Land Rover does the same thing and calls out the same spec also..
I personally feel that such a high interval between oil changes is what contributes to many instances of lifter tick noise that plagues a lot of the V8 cars these days. I plan to get mine changed every 5,000 miles and Just let the dealership worry about what oil to put in it.
Why would they decrease the interval when the same engine and oil are used from 2011 to 2015??
