Oil Change computer reset on 5.0L
Hey folks, I am ready to change my oil on my 5.0L engine. Can I get some instructions on how to reset the computer once job is done. Also, is the drain procedure straight forward. 1. Remove oil pan drain plug, 2. Remove
oil filter house change filter element. 3. Replace and add oil.
Thanks in advance to the certified techs.
> Resetting service reminder:
1. Press and hold rear fog lamp switch
2. Turn ignition on, do not start engine
3. Release rear fog lamp switch
4. Press and hold trip button (end of left side stalk)
5. Press and hold rear fog lamp switch
6. See "Resetting Service Light" message in message center
Received 2,192 Likes
Unless my memory is faulty, I didn't think there was a drain plug on the oil pan for the 5.0 engine; either that or the plug isn't used for draining.
