oil filter and drain plg location 2013 xf 3.0
Hi I'm new to the forum and basically new to Jaguar ownership. Love the great cars!! I'm changing the oil for the first time and trying to locate the oil drain plug and oil filter. I have the bottom shield removed and all parts ready to replace but wanted to make sure I don't remove any plugs that would be a mistake.
If anyone has a picture or diagrams to locate these things it would be greatly appreciated.
BTW: I have been working on and restoring older cars for many years so I'm not a newbe around cars.
Thanks in advance.
Thanks in advance.
I think I have asked too soon. After looking around underside and above the engine, I have figured out both the drain plug location and the oil filter location. Because I didn't have my glasses on and it was a little dark outside, I didn't see the obvious location of the drain plug. But I was surprised of the location of the filter canister which is on top of the engine and easy to remove and replace.
Now another question about the oil change process. On this car it doesn't have the obvious dipstick located on the side of the engine reaching down to the bottom of the crank case. What I see is, under the oil fill cap, is a nozzle hose about the diameter of a dipstick, but no dipstick in it. Until I get this car figured out, it is a chore. Thanks for your patience and help.
Daryl
Daryl
Received 3,259 Likes
dhvoorhees (09-18-2016)
Is there a dipstick or a way to check oil level? If so I can't find it.
There is no dipstick, only an electronic readout which you access by having the ignition on (but not the engine) and toggling the trip computer button. According to the manual this won't work unless you have warmed the engine up then let it sit for 10 minutes, but many have found (including me) that if you pop the hood/bonnet you don't have to wait.
dhvoorhees (09-19-2016)
Truly, unless you really like jacking, crawling under the car and taking off undertrays, buy yourself an oil extractor. Not expensive and this is how the vast majority of dealerships do it.
They attach directly to the Jaguar extraction pipe you noticed and that goes down very close to the bottom of the sump. It leaves very little old oil in there.
I bought one like this , only Pela brand.
There is no dipstick.
The oil level is viewed on your dash, electronically by scrolling through the menu using the button on the end of the indicator stalk.
You have to carefully keep an eye on how much oil you're putting in.
Oh, and make sure you get the correct oil. It's very specific.
It's only visible after 20 minutes (from memory) after the engine is shut down.
I've changed it both ways and vacuuming it out only leaves about 1/8 cup of oil in the sump if the car is level when doing it, vs draining it.
True. And really, there's more old oil than that that stays as a film on all interior engine surfaces. Unless you flush the old oil out, (which is done by no shop ever) there is always going to be old oil in there, even if you're patient and let it drain for an hour (which no shop did. ever).
The bit that's left will not effect anything.
More frequent oil changes are the better insurance.
oil specs XJ 2013
For my 2013 XJ v6 SC rear wd
The book seems to call for WSS M2C913 - c 5w30
but the oil cap calls for a 2W20 Castrol with no spec mentioned
Castrol web site (and Mobil 1 site) say they do not have an oil for this car.
Assuming it takes a 5W20, What WSS Spec does it need?
The dealer service folks have not been helpful.
That WSS M2C913C 5W30 oil is for the 3.0 litre diesel motor in the XF and XJ, see here: Ford WSS-M2C913-B Engine Oil
For the petrol 3.0 SC the recommended oil is Castrol Edge Professional 0W20, see here: http://www.jaguar.com/about-jaguar/castrol.html
Also see here: https://www.google.com/url?sa=t&rct=...scsHyRCs5ajZHQ
It is possible that some other 0W20 fully synthetic oils will be suitable, but to my knowledge this has never been confirmed despite numerous similar "what oil should I use" threads across multiple forums. It seems this particular Castrol brew has a specific type and amount of Titanium additive which no other oil has, and it is the only one recommended by JLR for the 3.0 SC.
Thanks for your response
That oil is not available in the USA and a 9W-20 is not recommended anywhere.
I'm having a problem determining the proper oil For my 2013 XJ v6 SC rear wd.
The owner's manual says 5W-30 WSS2C913-C. The oil filler cap says 5W-20 Castrol with no spec mentioned.
Castrol web site (and Mobil 1 site) say they do not have an oil for this car. but on the phone Pennzoil say a 2014 takes WSSM2C925-A.
The dealer service folks have not been at all helpful.
Thanks for your help.
Eric
2013 XJ portofolio 3 liter SC
1964 Lotus Elan Hart
1972 Yamaha R5 Racer
1960 Mk9 sold
1974 XJ6 sold
M
Eric
1960 Mk9 sold
1974 XJ6 sold
M
Eric
1960 Mk9 sold
1974 XJ6 sold
M
Eric
1960 Mk9 sold
1974 XJ6 sold
M
Doesn't your manual list the oil specs?
The lube specs and capacities may be useful for all members
Jag lube and capacities
For best print results, use the print button below.
2013
JAGUAR XJ 3.0L 6-cyl Engine Code DOHC LUBRICANTS &
FLUIDS:
2013 JAGUAR XJ 3.0L 6-cyl Engine Code DOHC LUBRICANTS
& FLUIDS:
LUBRICANTS & FLUIDS: Engine Oil
Grade 1......SEO17[1] No AMSOIL Product Recommendation
All TEMPS......5W-30
Automatic Transmission,8HP70......SL093 [2]
Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATL)
(ATLQT)
OE Fuel-Efficient Synthetic Automatic Transmission Fluid (OTLQT)
Differential, Rear Electronic Unit......GLS16 [3]
All TEMPS......
Differential, Rear Open Unit......GLS24 [4]
All TEMPS......
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Differential, Front......GLS24 [4]
All TEMPS......
Transfer Case,U/K TRC......GLS87 [5]
Fluids
Brake Fluid......HBH
AMSOIL Brake Fluid DOT-4 (BF4SN) [6]
Power Steering Fluid......PS035
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF)
(ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [7]
[1] Motor oil meeting Ford specification WSS-M2C913-C.
[2] Use Shell L12108 or equivalent.
[3] Use Castrol BOT 720
[4] Use Castrol SAF-XO
[5] Use Shell TF0870
[6] Shell DOT 4 ESL is preferred. If unavailable, a low
viscosity, DOT 4 brake fluid that meets
ISO 4925 Class 6 specification may be used.
[7] Use Mobil ATF320. FILTERS:
Air Filter MANN Air Filter
(C30115)
CHASSIS LUBRICATION:
0 Fittings, 0 Plugs
CAPACITIES:
Engine, AWD, with filter..........6.9 quarts [1]
Engine, RWD, with filter..........7.7 quarts [1]
Cooling System, Initial Fill..........14.3 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 8HP70 Initial Fill..........Not Specified
Automatic Transmission, Total Fill
8 speed 8HP70..........9 quarts
Differential, Electronic Unit Rear..........2.5 pints
Differential, Front..........1.1 pints
Differential, Open Unit Rear..........1.7 pints
Transfer Case, U/K TRC..........1.1 pints
[1] After refill check oil level. TORQUES:
Oil Drain Plug.....17 ft/lbs
Transfer Case
Fill Plug 44 ft/lbs
Drain Plug 44 ft/lbs
WSS superseded by WSSM2C945-A
2014
JAGUAR XJ 3.0L 6-cyl Engine Code [D] LUBRICANTS &
FLUIDS:
2014 JAGUAR XJ 3.0L 6-cyl Engine Code [D] LUBRICANTS &
FLUIDS:
Grade 1......SEO14[1] No AMSOIL Product Recommendation
All TEMPS......5W-20
Below -4 F......0W-20
(ATLQT)
Differential, Front......GLS24 [3]
All TEMPS......
Differential, Rear Electronic Unit......GLS16 [4]
All TEMPS......
Differential, Rear Open Unit......GLS24 [3]
All TEMPS......
Fluids
(ATFQT)
[1] Use motor oil meeting specification WSS-M2C925-A, WSS superseded by
WSSM2C945-A
except in
locations where temperatures fall below -4 F (-20 C). If
unavailable, or in locations where temperatures fall below
-4 F (-20 C) engine oil meeting Jaguar Land Rover
specification STJLR.51.5122 should be used.
[3] Use Castrol SAF-XO
[4] Use Castrol BOT 720
(C30115)
0 Fittings, 0 Plugs
CAPACITIES:
Cooling System, AWD Initial Fill..........9.5 quarts
Cooling System, RWD Initial Fill..........9.4 quarts
Transfer Case
Fill Plug 44 ft/lbs
2013
FLUIDS:
& FLUIDS:
(ATLQT)
All TEMPS......
All TEMPS......
All TEMPS......
Fluids
(ATFQT)
(C30115)
0 Fittings, 0 Plugs
CAPACITIES:
Transfer Case
Fill Plug 44 ft/lbs
2014
FLUIDS:
FLUIDS:
(ATLQT)
All TEMPS......
All TEMPS......
All TEMPS......
Fluids
(ATFQT)
WSSM2C945-A
except in
(C30115)
0 Fittings, 0 Plugs
CAPACITIES:
Transfer Case
Fill Plug 44 ft/lbs
Yes, I have changed my mind. I now believe that for the AJ126 and AJ133 petrol motors any fully synthetic 0W20 or 5W20 oil which meets the 925A or 945A spec is perfectly OK, and there is no need to stick to the special Castrol Unobtanium brew just because it has a higher level of titanium than most other oils.
