Oil levels
No.
If you are relying on the dipstick then 3/4 is ample. If yours has the electronic oil level display it tells you when you need to add oil.
A sump full to the "max" mark is no longer important because oil consumption is very low.
At 3/4 you still have more than 6 litres of oil in a 4.2 and even more in a 5.0 or 3.0 SCV6.
aholbro1
08-05-2021 05:02 AM
