Overheating/ Limp Mode - Will motor shutdown if overheating
Guys,
Curious after reading some stories on cooling system failure if our cars will actually shutdown if overheating, or if they will only enter limp mode all the while continuing to overheat. Will the car actually shutdown if it gets too hot?
Thanks!
Thanks!
So I've notice with my car rough idol weather engine is cool or not - some times on cold starts thick smokes -
I found when I release the air on the coolant reservoir tank at night- car would be good for a couple of days - no smoke no rough idol no lights-
my mechanic says these cars have a very high pressure in the coolant system-
But i know this is not normal- i already changed out water pump due to leaking - and changed out plastic coolant pipes that were found leaking as well - also changed out Reservoir with cap- all OEM parts
Has anyone experienced this issues ?
Im using orange coolant prestone 50/50
