was hoping someone might be able to give me some help. For a while now whenever if hit the higher end revs 27500 plus for a period of time I get the dreaded RP red error. After engine ignition cycle the errors is gone and drives fine again until next time i typically hit to motorway
I connected to SDD and no codes, so after much reading on this site i changed fuel filter and air filter. This definitely helped and the RP error dosnt come on quite as fast but it still does. After connecting many time I eventually got a code. It gave me the P006A. Since then I have cleaned the maf sensor with specific cleaner and again no luck.
I have then do a full inspection of all the pipes and found the below
I’ll have took a zoomed out picture too below
I would expect this to be my issue
my question is does anyone know what part this is? Any tips on replacing it and would I be correct in suggesting this is the issue?
