P010C fault code help please
Tous les articles en Anglais s'il vous plaît.
The error code has the following possible causes:
1. an air leak
2. blocked air filter
3. blockage in the induction pipe
4. a harness ground fault
5. a harness power fault
I’m not t a diesel car, but if you have two mass air flow sensors swap them and see if you get a different code. If you have one, you’re mass airflow sensor probably went bad. You could attempt to clean it and see if it works. But usually in my experience it’s done or on it’s way.
i recently got a mass airflow code for B and it went away after I replaced the faulty sensor.
Nathanmatthew77
09-08-2018 08:56 AM
