P2565
P2565
2013 XF 3.0L V6 AWD, supercharged
Getting code P2565
"Turbocharger Boost Control Position Sensor A Circuit High"
Looking through the forum, it seems that my supercharge bypass valve actuator might be faulty (or is not getting power or ground). Is this a part that I'd be able to access to replace? Is it found under the hood or from below the vehicle? I lift the hood, remove the cover & am unable to see anything that looks similar.
I tried YouTube & couldn't seem to find anything of guidance. I'm hoping that someone else would be kind enough to provide some guidance as to how I should proceed.
Getting code P2565
valuefresh (02-02-2022)
Supercharge bypass valve actuator location
Thank you! I did notice that thread before I posted.
I'm having trouble understanding where my Supercharge Bypass Valve Actuator is actually located. Wondering how accessible it might be, to replace myself?
When I lift the hood I think I'm getting hypnotized by what is probably just the supercharger air intakes. I attached a picture. I'm willing to look from underneath, but I'm not sure where to look - in the general vicinity? I did tons of repairs on my last Jaguar, but this one seems to be far more restricted, harder to understand, with very few YouTube video's - as compared to my last one.
WOW, fantastic - thank you so much! I actually blindly jiggled those today & the check engine light has been off since. So it might be a connection problem? Or perhaps it inadvertently went away but will return, like the member in the other post? Either way, now that I know where it is, I'm confident that I can replace it myself.
If the error message comes back or keeps coming back & I replace the part (AJ813841 @ $275 from the dealer), I'll return to this post to update, for other members.
Thank you again. I really appreciate you for taking time to help me.
davetibbs (02-03-2022)
Problem solved
Thank you again to NBCat & Davetibbs for helping this rookie with his P2565 code, despite my embarrassment that the part I was looking for was right in front of me - at the top of my engine. I reset the code a couple of times & it came back within a few days (3 days the first time, about 7 days the next time).
PROBLEM SOLVED by replacing my supercharge bypass valve actuator (AJ813841).
In case another rookie is reading this, all I needed was the following tools (the small ratchet, $10 from Autozone). For the seasoned mechanics, please excuse me as I realize that you have plenty of tool choices to access restricted areas & this one isn't so restricted.
I've also included a picture of the underside of the connector, since it's hard to see underneath, in case you'd like to disconnect that first (I used a small pick, but of course a flat head screwdriver would do).
All I needed was these tools for the two 8mm (5/16") bolts
Plus I used a little (curved) pick for the underside of the connector which I decided to remove 1st.
davetibbs (03-05-2022)
polarisnavyxj
06-18-2016 12:37 PM
