park brake fault. Replace parking brake motor,cannot clear fault code. Please help.
Back tracking a little, how sure were you that the parking brake motor was really the cause of the "park brake fault". Low battery and poor connector contact can sometimes jam the parking brake. Not sure if the XF has the same set up as the X350. In the latter, the system resets itself automatically, guiding you by dash messages, once you disconnect and reconnect the parking brake motor.
Jagernaut
30
08-17-2014 05:47 PM
