Parking brake motor replacement?
Good suggestion. I'll take a look around there. It looks like if it doesn't go the way I want it to, it shouldn't be too hard to put it back where it was until I have time to drop the axle. I just really, really don't want to have to.
Try this one.
https://www.jaguarforums.com/forum/s...e-sale-112817/
If you follow the links in the replies in that thread you will find a guy who opened up the motor and took pictures of what fails.
See if this helps??
See if this helps??
Thanks! I took a look through the TSBs and such and it looks like they're just doing exactly what I was when verifying it was the motor itself. All cables and components look fine to me. The odd thing is that after I do a reset on it, the brake will work the first time, then it will give an error after it releases and not try again. I'm not entirely convinced the gears are fubar in the motor assembly, but I don't see anywhere else it may have gone wrong.
Jaguar Forums Editor
F-Pace (X761) / C-X17
04-28-2016 03:48 PM
