I need help identifying the part I marked with pink/red in the attached pictures. It is located at the lower edge of the rear springs where they sit on the dampers. You can see from the pictures that the part is specifically shaped so that the springs seat in it. The EPC shows a part called "spring packer", part # MJA2162AA. My searches on that part number show a flat packer, not an item shaped like in the attached pictures. Can anyone help me identify this part? Is it available as a separate part or is it only included with springs? Please let me know if you have any information that will help me. Thanks
Great research! I find the exact same thing??
Now I did find a picture and I think your right? The part you marked looks to come with the spring? At least from this picture?
Part number C2Z8373.
I’m not sure what to call that part. On other models, such as the E-pace, I think it’s called an isolator, or spring seat. Almost all pictures I find of the XF springs are without the isolator, unless it’s a complete spring and damper assembly. I’d really like to confirm if the isolator has a part number or if it is only included with springs.
