Passenger side windows not working
Old 06-24-2024, 09:44 AM
RobinL's Avatar
Default Passenger side windows not working
Hi,So suddenly my (right) side passenger window stopped working.All I heard was some whirring sound from the door.Changed the window regulator mechanism completely with motor.Did not change the sound and found that it was coming from the control module in the door.Replaced it with a new (second hand) unit, no noise anymore but no movement in front and rear passenger window.Before replacing, the rear window still worked.Tried to put the old one back in, no noise, no movement either.Put the "new" one back in.Checked the fuses in the footwell and luggage compartment, no relating fuse is burned.Also noticed the mirror controls dont work anymore.Clueless of what I could try next.Please help.
Old 06-26-2024, 11:33 AM
sportbrake_phil's Avatar
Did you configure the "new" module with SDD?
Old 06-26-2024, 12:19 PM
RobinL's Avatar
No, I will look into it how to do this.
But shouldn't the old module still make the sound like it did before replacing?
Old 06-27-2024, 11:12 AM
I wouldn't have though the old module should make a noise in the first place, so maybe it won't get back into quite the same state now it's been powered off.
scottpeterd
05-28-2022 10:45 PM
edreddy
04-20-2022 05:19 PM
Hanso
05-06-2017 09:56 AM
93leaper
XJ40 ( XJ81 )
10-20-2007 07:26 PM
Quick Reply: Passenger side windows not working
