Pedal positions on XF AWD
More of a did you notice what I did question...
I was given a 3.0 AWD to drive for a couple hours while the dealer was making adjustments to my '12 Portfolio. I do, by far, prefer the V8 to the V6, but that's a separate issue.
What I noticed, though, is that it seems like the transmission tunnel has been made wider and the accelerator and brake pedals are quite noticeably closer together on the AWD model. Enough so that my (not unusually wide!!) foot would sometimes catch on the brake pedal when I let up on the gas to apply the brake.
Anyone else notice this?
You are at least partially incorrect about the location - the transer case would be located at about the hip position while seated, but the front differential clearly protrudes out to the left at about the position of the feet (see attachment).
I'm pretty certain they had to rejigger things a bit. I wonder if this is only the case on the AWD, or if they did it across the board for simplicity. By the way, as I originally stated, I'm not seeing this as a problem (though people with wide feet might just find it not to work very well for them), but as an observation of what needed to be done to get something to work that wasn't originally part of the plan.
I think the 8 spd transmission is no bigger than the 6 spd. It is lighter.
The front driveshaft will be below the pedal box by the time it reaches the left side of the sump where the front diff is bolted.
I have not compared the two footwells but I am not conscious of there being any difference.
Now I am intrigued and will investigate further.
derek15301xjr
10-20-2015 07:39 PM
xjrjag
09-24-2015 10:08 PM
hen555
09-07-2015 11:13 PM
