I found this wedged between lower front corner of the LH front door and door jamb. Even when looking at the RH side I cannot find out where it belongs. It could of course be that it has fallen off totally at the RH side. Does anybody know where it belongs? Alternatively could you post a photo or three of the gap arounf the hinges with the door fully open?
Outside, i.e. facing the door as found.
Inside, i.e. facing the hinge area of the door opening.
OK found out where it goes: It sits beneath the upper rear edge of the front wing. Part of the wind noise sealing. The seal is damaged but I believe I can fins some sealing to repair and then back it goes with a blob of glue. No wonder I thought the wind noise had increased lately.
