Please Dock Device -------
I get this message at seemingly random intervals, only when starting up the car and turning on the audio (I usually turn off the audio and climate control before turning off the car). This has been happening more frequently as of late. Very annoying. I have to turn off the audio, make sure the drive isn't being accessed, remove, turn on audio which prompts the message again, and re-attach.
I have a 16Gb Sandisk Cruzer micro in the USB port with most of my music. Best audio quality of the 3 inputs. Under normal operation, sounds great, when I turn off the audio or the car completely and come back it remembers which song I was on and continues from there. Proper random mix. Basically works beautifully 90% of the time.
This sounds like the very annoying XM presets disappearing on models equipped with XM. Could they be related? Any insight greatly appreciated.
Thanks in advance.
Thanks in advance.
Hmmm, I have XM and hae never lost my presets.
I have, however, encountered what seems to be a known issue with some bluetooth devices, that being the XF sometimes fails to properly disconnect when you shut off the car, resulting in battery drain, enough to completely kill the car after about 2 days. I was told by Jaguar there isn't yet a fix for this issue.
Thanks in advance.
Thanks in advance.
I wish it played .flac files
I can confirm this, I bought a Corsair Flash Voyager 32GB and have not had the problem since.
I'm having the same issue with my SanDisk Cruzer Fit CZ33 32GB USB Flash Drive (SDCZ33-032G-B35). The car frequently tells me to dock the device, even when it never left the USB, and when it finally does recognize it, it always restarts from the first track in the first folder. I usually have to remove it from the USB several times to get it work properly. Other times, it fires right up (but always on the first track in the first folder). Extremely frustrating.
Thanks for the tip! I've been fighting mine for two months with no luck. Took to Jaguar dealer yesterday and they said USB port tested fine. So stopped by Walmart and purchased a couple of Gorilla drives and so far are working great!
