pls help p0175 bank 2 rich after supercharger removed and reinstalled at shop
Hi all that damn Jag is driving me crazy again. Had to ported rebuilt supercharger removed so I could have a bearing replaced and after the car was put back together I get a p0175 code and no others. Changed MAP and both MAF sensors no change. Have reset and cleared code 5x after about 40 miles it returns. Car seems to have a random stutter when driving, accelerates hard. Injectors were replaced about 2k ago as regular maintenance. on a autel diagnostic test it showed the map at -30 volts so I replaced it. Showed no misfires short term trim bank 1 14.06 bank 2 11.72 . My fuel rail pressure was 9880 kpa likely the tune, Didn't see anything else array. Is this a bad injector? 02 sensor is there ways to rule either out. Love this car been through alot but it driving me crazy. Thank you for any insight
BugDoc
08-12-2009 06:51 AM
