Is it possible?
Is it possible?
I realize this may be a nit to pick...but, is there any programming in the tranny ECU that can be done to set the default ratio for starting from a stop to the first gear rather than starting in second?
I've been manually selecting first at stop lights; with the 2.0T engine, it just seems to have a smoother take off in first from 0 than starting off in 2nd.
Of course, that means the first shift up as you accelerate has to be with the flappy paddle, then hold the paddle in to put back into auto, but, like remembering to press the ECO off button on the later versions, thinking that tailoring the conditions like this to the owner's preferences should be something JLR should have thought about.
Thoughts? Or has anyone investigated this?
Seems to me that there should be some way of programming 1st as the default from-full-stop gear. Having to go thru all sorts of gyrations to do so (and Panels, I tried your sequence and it did work nicely) just (like not being able to set the default eco mode to off) grates on me a bit. Doesn't decrease the pleasure of owning one of these fine autos, just a nit that needs scratching...
I'm with you boiler "there should be some way of programming 1st as the default from-full-stop"
Unfortunately, my 2011 6 speed will NOT do this little trick. You can go to "S" and paddle shift to "1", but then the selector will not move left past "D" for several seconds before going to "N". I believe this is part of the change when the factory reflashed all 385hp cars in that model year to remove shift paddle functionality in "D".
FS[Western US]: XJ6 console wood set- 1990-1997 Beautiful
XJsc-guy
10-09-2015 10:28 AM
