Power Steering Fluid Change
I used RedLine full synthetic D4 as this used to be their recommendation, but they now have a line of PS fluids . RedLine has an application guide on their website http://www.redlineoil.com/Products.aspx?pcid=27. I use the same oil changing suction pump I bought on Alibaba for changing the engine oil, gets 95% of the oil out of the reservoir and sump.
fastlanz (04-06-2016)
I get this stuff from the dealer..it's what he uses, so I can't go wrong..
(click on this) Mobil ATF-320 PAS
Apparently this stuff is brewed for the UK market,,I'm sure there is something equivalent here OTC at Auto parts stores..I just use the Mobil ATF 320 I get from the dealer and to hell with looking for something else...
Thanks for all the information guys. Much appreciated.
While we're on the topic of fluid change does the supercharger use oil from the engine? Also is the rear differential sealed? I'm thinking of tackling these items next as well as a transmission oil change. Nice write up on the forums for the transmission oil change. Sounds like if you can get the bolts out your golden otherwise not so much..
RE: Rear Differential: As with mine, I assume your's is the same..there is a fill plug near the top of the back of the pumpkin..You have to suck out as much of the old fluid as you can...plenty of suckers at the auto parts stores..and pump in the new lube...(1.24 liters)
Again a dealer provided lube;
Castrol BOT 750B
Castrol BOT 750B
Received 3,225 Likes
Re supercharger oil - completely separate from the engine oil and a PITA to replace, see this thread: https://www.jaguarforums.com/forum/x...er-oil-153183/
U
Our superchargers need an oil change before a possible 100kmi rebuild only if they are tracked regularly or it is opened up before that distance (mine was actually rebuilt by Eaton at 60kmi for noisy bearings).
The SC/XFR and XFRS utilize an Electronic or Ediff, it has a drain plug on the bottom and a fill plug on the side.
The trans really isn't a hard job actually the hardest part was getting the car level on jack stands for the fill process, you also need a way to measure the trans fluid temp during the fill process, I used a multimeter with ir temp reading, I just shot it at the pan. I wrote up both processes.
I also have a link in one of my post for the complete 09 to 11 XFR service manual as a download.
While we're on the topic of fluid change does the supercharger use oil from the engine? Also is the rear differential sealed? I'm thinking of tackling these items next as well as a transmission oil change. Nice write up on the forums for the transmission oil change. Sounds like if you can get the bolts out your golden otherwise not so much..![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
fastlanz (04-07-2016)
Great info. I think I'll let my mechanic tackle the supercharger oil and breaking the bolts free from the transmission pan. Rear diff sounds doable.
This would make life much easier getting under there..
Lift Stand for a car: How to use a floor jack - YouTube
Thanks for the link to the manual. It will be a very valuable resource.
I noticed you have nice mod list. Are there any mods besides the tune / pulley that you really enjoy or noticed a significant improvement? I did the brakes last year with new high carbon rotors / EBC red pads but was curious about your other mods such as the tcp intake, intercooler pump etc...
As fer as mods, The tune and pulley where the only mods that showed me a significant gain in the seat of the pants, and if you do that too your XFSC by having it tuned to the XFRS level boy will you be surprised..lol THIS IS A STEAL →→→→https://www.jaguarforums.com/forum/x...-cheap-160258/..
Having said that most of my mods where for longevity,
TCP intake was done because the stock plastic one broke a mount, the TCP was actually less than a new one from Jag.
Die Hard Gell cell was just the best battery I could fine that fit in the car right after I got a low batt warning.
Plugs, did smooth out the idle (The most challenging) but were done because I don't like long interval ANYTHING! Factory plugs are covered by the 80kmi Federal emissions warr though, Champion warr my replacements for 7 years unlimited mi.
K&N Filters done as I'll never need to buy replacements, and regardless of what others say I've used K&N products for the last 20 years or so, we also use K&N filters on our 30 hp, run 24/7/360 day plant vacuum blowers (10 Total) for the filters great flow even while dirty, dirt collection and ease of maint (reuseable). I have been on a tour of the K&N HQ, dyno (Where there filters ALL HP gains claims are verified) facility, and production plant as they are HQ right here in Riverside CA. K&N does a dyno day every year and is the contracted dyno for all Motor Trend and Edmonds HP verification testing.
The IC pump was done as a preventive measure, they go out with no warning at around 50 to 70kmi. I drain and refill my coolant once a year so since I was going to be under the car anyways right? Jag wants about $400 just for the pump, I got the Bosch 010 for $99 and if it's good enough for AMG.
Cool thanks. Funny you mentioned the tune and pulley.. lolllll. I saw that ad too... Looking forward to feeling the difference especially in the midrange. Hopefully will not be breaking any half shafts as I read the xfrs has a beefier driveshaft/half shafts. You wouldn't think 30 torque would make that much of a difference but the 1/4 mile runs are impressive. Will have to work on my launches...
giandanielxk8
03-15-2022 08:45 PM
WTB[NorthEast]: X-Type - Wood steering wheel wanted
Guernz
03-24-2016 08:53 AM
