Prefacelift stereo upgrade available, Tesla style.
Here - try these guys for your questions. I bought mine from them. They've been responsive both before and after purchase and their product has a 2 year warranty fwiw. Realistically, these are all just retailers of the product and its essentially the same option choices wherever you buy.
There is no wire cutting btw. The speaker wires are part of the unit and will fit into the OEM gray plug. You would need to add ferrule crimps to the wires but that's it. Also, it's only an assumption that base audio is a problem. It was a problem for one person on the X150 thread.
https://www.aliexpress.com/item/1005...archweb201603_
Good luck fellas
Good luck fellas
Created the second part of the video.
In the video I ask for the black connector. I realized that I am an idiot, becasue that one is for the home and door lock etc. buttons on the wooden bar between the screen and the CD player.
I also realized that I most probably need a socket for the second grey connector, which I thought has to stay in the CD player. I am not sure anymore, becasue there is exactly one free space on the head unit.
Hunnenkoenig (02-06-2021)
Thanks for helping on more information about this.
I got bored dealing with, aliexpress sellers so I got in contact with a factory. I have had some updates on some features, i got some videos and confirmation of heated steering wheel function and climate seats, but it appears there's no RHD trim yet. They even have better prices, but buying outside of aliexpress, is risky.
There's only Black trim available, I'm having a very hard time deciding, i just love the xfr dark wood and aluminium trim, not sure if I'm willing to sacrifice that for a bigger screen.
This is from the xk thread....... I have SOUND! I disconnected the battery terminals, touched them together and swapped out the red-white RCA audio connections to another input (labeled as audio OUT, not audio IN) and I'm able to get sound from the new Tesla-style video screen. I immediately disconnected the straight settings and reconnected all of my ACM connections and after a brief delay ... SOUND!
#28
FWIW, the Blue connector is GVIF. It's what displays the image from you (now no longer needed) Nav Unit.
Don't make the assumption that you're missing a connector. You likely are not. That one in the Tesla style unit remains unused on the X150 as well. It's possible (but I don't know) that it's reserved for an optional add on.
Which sound system do you have installed? I ask because that that unused gray connector in the pic could be for speakers depending on which entertainment system you have. I see there multi colored speaker wires coming out of the unit. You may need to connect wire to wire. Before doing anything with those, try plugging the connector back into the CD player. I'm not familiar with your vehicle. If the player is still connected to your sound system, those are probably the speaker wires. If that doesn't work, leave it plugged into the CD player and try swapping the MOST line labeled IAU (Integrated audio module) and with the one labeled ICM (Information and Entertainment Control Module) Plug the ICM into the can bus box and see if you get sound.
EDIT - I watched your Video.
The smaller grey connector is, as you say, actually the speaker cables.
I have to attach the loose speaker cables from the unit to that grey plug, either cutting off the plug and tying the cables together, or tinkering some pins and stick them into the plug.
I tried with the cables putting into the plug and I got sound.
All other RCA cables don't do anything for me.
I have apparently just the base sound system.
#31
These are universal units and they have so many cables because they need to fit all variations.
I have a Jaguar since October last year and I was never a big Hi-Fi guy, so I don't know all those devices :-)
I bought my car how it is. For me it sounds good enough without any pimped sound system :-)
#32
Thank you Sean! Meanwhile I figured it out based on your x150 thread.
#34
https://www.youtube.com/watch?v=2nOxiXDFh70
#35
The device even told me that the door is open, so I think, the sensors will work too.
Actually all the connectors are used, so everything has its place. Nothing is left out. The only one is that speaker plug.
I am pretty sure that the sensors will work. I think I saw one on the right back corner displayed on my screen with the yellow-red wave lines.
#36
The following 2 users liked this post by Hunnenkoenig:
John Williams (02-07-2021),
Sean W (02-07-2021)
#37
Sean W I don't think it really matters how you connect the plugs on the MOST because your just making a loop for the fibre optics. When you add a unit to the network it's just an in or out to continue the loop!
I'm wondering if the speakers connect the same way when you have the high end audio system with the amp & sub??
#38
#39
It's probably the reason, why hunnenkoeing FO cables are not doing anything as he describes since he doesn't have amp. He probably doesn't even need the blue box.
Just guessing...tho.
